OneVü Sonar Options
To change the options and settings for the OneVü™ sonar view, select Options.
Contrast
Sets the contrast for the sonar view, which increases the difference between the lightest and darkest areas of the reading.
Brightness
Sets the brightness of the sonar view.
Frequency
Sets the frequency used by the transducer. You can select between Chirp 455 kHz, 810 kHz, and 1070 kHz frequencies based on your needs.
Range
Sets the distance of the range rings on the sonar view.
OneVu™ Scan
Starts and stops OneVü scanning. Select Menu button to adjust the scan settings.
OneVu™ Scan > Scan Mode
Sets the method used to control when the scan runs. Select Constant to run the scan continuously. Select Manual to scan only when you choose to initiate a new scan. Select Auto to engage the scan automatically when the vessel enters a new area.
OneVu™ Scan > Speed
Sets the speed of the scan.
OneVu™ Setup
Sets additional OneVü sonar settings (OneVü Sonar Setup).
September 2026
