Radar Setup Menu
From a radar screen, select Options > Radar Setup.
Source
Selects the radar source when more than one radar is connected to the network.
Chart Display
Shows the chart under the radar image. When enabled, the Layers menu appears.
Orientation
Sets the perspective of the radar display. You can choose to orient the radar display so "up" is determined by north, your heading, or your course. You can also choose to orient the radar display more like a chart using the North Up True Motion option.
Orientation > North Up True Motion
This setting orients the radar display with north up, but not centered on the vessel. In this view, the vessel indicator moves across the screen while stationary objects remain fixed. This may help when visualizing the movement of the vessel relative to the land and other detected objects.
Stabilization
Sets the method used for calculating movement for the vessel and for detected targets. The Ground option uses Course Over Ground (COG) and Speed Over Ground (SOG) when calculating object movement. The Sea option uses Speed Through Water (STW) when calculating object movement. When using the Sea option, you can select Menu button and enter the water speed manually if needed.
Crosstalk Rej.
Reduces the appearance of clutter caused by interference from another nearby radar source.
Rotation Spd.
Sets the preferred speed at which the radar rotates. The High Speed option can be used to increase the refresh rate. In some situations, the radar automatically rotates at the normal speed to improve detection, for example, when a longer range is selected or when MotionScope or Dual range is used.
Appearance
Sets the color scheme, look-ahead speed, and navigation appearance.
Installation
Allows you to configure the radar for the installation, such as setting the front of the boat and the antenna park position.
Reducing Cross Talk Clutter on the Radar Screen
You can reduce the appearance of clutter caused by interference from another nearby radar source, when the cross talk reject setting is on.
NOTE: Depending upon the radar in use, the cross talk reject setting configured for use in one radar mode may or may not be applied to other radar modes or to the Radar overlay.
From a radar screen, select Options > Radar Setup > Crosstalk Rej..
September 2026
