Changing the Center Location of the Radar Screen
If you want to view readings farther from your location in one direction without adjusting the radar range, you can change the center of the radar screen so it is not on your vessel location.
NOTE:
You cannot adjust this setting if you are using the Look Ahead option to shift the radar screen ahead of the vessel at a set
speed.
- From a radar screen, select .
Select
and drag the crosshairs indicating the boat position to adjust the center of the radar screen.
Parent Topic: Adjusting the Radar Range
