Water Layer Settings
From a chart, select Options > Layers > Water.
NOTE: The menu may contain some settings that are not supported by your installed charts or your present location. If you make changes to those settings, the changes will not impact the chart view.
NOTE: Not all settings apply to all charts, views, and chartplotter models. Some options require premium maps or connected accessories.
Depth Shading
Specifies an upper and lower depth to shade between (Depth Range Shading).
Shallow Shading
Sets the shades from the shoreline to the specified depth.
Spot Depths
Turns on spot soundings and sets a dangerous depth. Spot depths that are equal to or more shallow than the dangerous depth are indicated by red text.
Fishing Contours
Sets the zoom level for a detailed view of bottom contours and depth soundings and simplifies map presentation for optimal use while fishing.
Relief Shading
Shows the gradient of the bottom with shading. This feature is available only with some premium maps.
Sonar Imagery
Shows sonar imagery to help show the density of the bottom. This feature is available only with some premium maps.
Lake Level
Sets the present water level of the lake. This feature is available only with some premium maps.
September 2026
