Editing a Saved Route
You can change the name of a route or change the turns the route contains.
  1. Select Where To > Routes.
  2. Select a route.
  3. To change the name, select Pencil icon, and enter the name.
  4. To change other items in the route, select Edit Route and select an option:
    • To edit a turn from a list, select Edit Turns > Use Turn List, and select a turn from the list.
    • To select a turn using the chart, select Edit Turns > Use Chart, and select a location on the chart.
    Modifying a turn that uses a saved waypoint does not move that waypoint, it relocates the turn in the route. Moving the location of a waypoint used in a route does not move the turn in the route.
September 2026
