Inserting Memory Cards
The internal card readers onGPSMAP® 7x3, 9x3, 12x3, and 15x3 series chartplotters support up to a 32 GB microSD® memory card, formatted to FAT32 with speed class 4 or higher1. Use of an 8 GB or larger memory card with speed class 10 is recommended. As of software version 34.00, GPSMAP 16x3 series chartplotters support up to a 1 TB microSD memory card, formatted to exFAT with speed class 10 or higher.
NOTE: When you insert a new memory card into the chartplotter, the chartplotter starts writing private information onto the newly-added card.
  1. Open the weather cap 1 on the back of the chartplotter.
    Memory card insertion with callouts
  2. Insert the memory card 2.
    There is no difference between the two card slots on the chartplotter. Any compatible card can be inserted into any open card slot, and it will be read by the chartplotter.
  3. Press the card in until it clicks.
  4. Clean and dry the weather cap.
    NOTICE
    To prevent corrosion, be sure the memory card and weather cap are thoroughly dry before closing the cap.
  5. Press the weather cap firmly shut.
1 As of software version 34.00, you can connect an external USB card reader to a GPSMAP 7x3, 9x3, 12x3, and 15x3 series chartplotter and use a memory card up to a 1 TB, formatted to exFAT with speed class 10 or higher.
September 2026
