Backup camera settings
Select Settings > Wireless Camera and select the backup camera name.
Flip Video
Allows you to flip or mirror the video.
Guidance Lines
Sets preferences for guidance lines displayed on the camera video.
Rename
Allows you to rename the paired camera.
Set Default Camera
Sets the order in which cameras appear in the camera view. The camera at the top of the list is the default camera and appears first each time the camera view appears.
Unpair
Removes the paired camera.
Automatic Activation
Enables the Garmin® navigation device to display the default camera view automatically each time the navigation device is turned on. If the navigation device is connected to an ignition-switched power outlet, this feature allows you to view the backup camera automatically when you start your vehicle.
Video Resolution
Allows you to set the quality of the camera video. Higher resolution settings provide a more detailed image but use more battery power.
NOTE: This setting is not available for all navigation device product models.
GUID-3D42553F-058C-48E4-9E9B-0BF243FDE816 v5
October 2024
