Tips for Installing the Headlight
  • Select a secure location to mount the device where it does not interfere with the safe operation of your bike.
  • Select a mount that best fits your bike.
  • Install the device correctly. The device faces forward, and must be mounted underneath the handlebars (Installing the Out-Front Mount).
    NOTE: Mount the device 400 to 1200 mm above the road.
    Device mounted on a bike
  • Make sure there are no obstructions in front of the light.
  • Adjust the headlight angle so it illuminates the ground ahead.
    NOTE: The setup of the lamp must ensure that it is working glare free.
  • To correctly line up the headlight, use the camera preview feature on the Varia™ app (Camera Settings).
  • If using an Edge® bike computer, install the mount so the bike computer is visible from a comfortable riding position.
  • Go for a test ride during the day in a safe environment.
GUID-3CB16656-5588-4399-88AE-E1626EC23030 v2
April 2025
