Charging the Device
NOTICE
To prevent corrosion, thoroughly dry the USB port, the weather cap, and the surrounding area before charging or connecting to a computer.
The device is powered by a built-in lithium-ion battery that you can charge using a standard wall outlet.
NOTE: The device does not charge when outside the approved temperature range (Specifications).
  1. Pull up the weather cap Callout number 1 from the USB port Callout number 2.
    Back view of the device with callouts
  2. Plug the USB cable into the charging port on the device.
  3. Plug the other end of the cable large end of the USB cable into an AC adapter or USB charging port.
  4. Plug the AC adapter into a standard wall outlet.
  5. Charge the device completely.
    The status LED flashes Green while charging. The status LED is solid green when charging is complete.
  6. Remove the USB cable, and close the weather cap.
GUID-3CB16656-5588-4399-88AE-E1626EC23030 v2
April 2025
