You can edit the range, direction of fire, and wind information.
From the
Applied Ballistics® app, press
START.
Select
Quick Edit.
TIP:
You can select
DOWN or
UP to edit each value, and select
START to move to the next field.
Look directly into the wind to accurately set the
DOF and wind direction.
Set the
DOF value to your actual direction of fire (either manually or by using the compass).
Set the
DIR value to
12:00.
Press
BACK to save your settings.
