Can I use my Bluetooth sensor with my watch?
The watch is compatible with some Bluetooth® sensors. The first time you connect a sensor to your Garmin® watch, you must pair the watch and sensor. After they are paired, the watch connects to the sensor automatically when you start an activity and the sensor is active and within range.
  1. Hold MENU.
  2. Select Sensors & Accessories > Add New.
  3. Select an option:
    • Select Search All Sensors.
    • Select your sensor type.
    You can customize the optional data fields (Customizing the Data Screens).
Copyright © Garmin. All rights reserved.GUID-3B607AEB-9EB5-4BF3-A38D-1F9926BB9F65 v5
