My music cuts out or my headphones won't stay connected
When using a tactix® Delta watch connected to Bluetooth® headphones, the signal is strongest when there is a direct line of sight between the watch and the antenna on the headphones.
If the signal passes through your body, you may experience signal loss or your headphones may become disconnected.
If you wear your tactix Delta watch on your left wrist, you should make sure the headphone's Bluetooth antenna is on your left ear.
Since headphones vary by model, you can try wearing the watch on your other wrist.
If you are using metal or leather watch bands, you can switch to silicone watch bands to improve signal strength.
Parent Topic: Troubleshooting
