Calibrating the Muzzle Velocity
Calibrating the muzzle velocity provides a more accurate solution in the supersonic range for your specific firearm.
  1. From the Applied Ballistics® app, press START.
  2. Select Profile > Gun Properties > Calibrate Muzzle Velocity.
  3. Select an option:
    • Select Range to edit the range.
    • Select True Drop to edit the drop distance.
  4. Select Check mark.
Copyright © Garmin. All rights reserved.GUID-3B607AEB-9EB5-4BF3-A38D-1F9926BB9F65 v5
