Adding a Profile
You can add a .pro file that contains profile information by transferring the file to the AB folder on the device.
- From the Applied Ballistics® app, press START.
- Select .
Select an option:
To customize the bullet properties, select Bullet Properties (Editing Bullet Properties).
To customize the gun properties, select Gun Properties (Editing Gun Properties).
To change the units of measure for the output fields, select Output Units.
Parent Topic: Profile
