Pairing the zūmo R1 Radar System with Your Motorcycle Navigator
Before you can pair your devices, you must ensure both the zūmo™ R1 Radar and motorcycle navigator are installed on the motorcycle and connected to power.
The first time you connect the zūmo R1 Radar system to your motorcycle navigator, you must pair both devices using Bluetooth® technology. After the initial pairing, the motorcycle navigator automatically connects to the zūmo R1 Radar system when it is active and within range.
  1. Bring the motorcycle navigator within 3 m (10 ft.) of the zūmo R1 Radar system.
    NOTE: Stay 10 m (33 ft.) away from other sensors that use Bluetooth technology while pairing.
  2. From the motorcycle navigator, select Apps > zūmo R1 Radar > Connect Now, and follow the on-screen instructions.
  3. While the zūmo R1 Radar system is powered on, hold the device button for 5 seconds to enter pairing mode.
    NOTE: If you hold the device button for 8 seconds or longer, the radar enters demo mode (Exiting Demo Mode).
    The status LED flashes blue. The device is in pairing mode for 3 minutes or until you press the device button to exit pairing mode.
  4. When prompted, select Yes to select the zūmo R1 Radar system.
  5. Follow the on-screen instructions.
When the zūmo R1 Radar system is paired with your motorcycle navigator, the status icon turns blue.
GUID-3B03A850-46B2-47F7-B7AF-7CD84686A1DA v3
August 2026
