Device Care
NOTICE
Avoid contact with chemical cleaners, solvents, gasoline, oil, insect repellents, or sunscreen. These chemicals can damage plastic components and finish.
NOTICE
Thoroughly rinse the device with fresh water as soon as possible after exposure to chlorine, salt water, sunscreen, cosmetics, alcohol, or other harsh chemicals. Prolonged exposure to these substances can damage the plastic components and finish.
NOTICE
Do not store the device where prolonged exposure to extreme temperatures can occur, because it can cause permanent damage.
Cleaning the Device
NOTICE
Do not use a dry cloth to clean the LED lenses. Use of a dry cloth may damage the LED lenses.
NOTICE
Avoid chemical cleaners and solvents that can damage plastic components.
  1. Wipe the outer casing and LED lenses with a soft, non-scratch cloth dampened with water or isopropyl alcohol.
  2. Wipe the outer casing dry, and allow the LED lenses to air dry.
GUID-3B03A850-46B2-47F7-B7AF-7CD84686A1DA v3
August 2026
