Distance Recording
The watch measures and records distance by completed pool lengths. The pool size must be correct to display accurate distance (Setting the Pool Size).
TIP: For accurate results, swim the entire length, and use one stroke type for the entire length. Pause the activity timer when resting.
TIP: To help the device count your lengths, use a strong push off the wall and glide before your first stroke.
TIP: When doing drills, you must either pause the activity timer or use the drill logging feature (Training with the Drill Log).
GUID-3A791586-B59F-4B37-B9C5-5A41F8C6BE0B v9
January 2026
