System Settings
Hold UP, and select Menu symbol > System.
Language
Sets the language displayed on the watch.
Passcode
Sets a four-digit passcode to secure your personal information when the watch is not on your wrist (Setting Your Watch Passcode).
Time
Adjusts the time settings (Time Settings).
Backlight
Adjusts the backlight settings (Changing the Backlight Settings).
Sounds
Sets the watch sounds, such as key tones, alerts, and vibrations (Setting the Device Sounds).
Do Not Disturb
Turns on or off do not disturb mode. You can use the During Sleep option to turn on do not disturb mode automatically during your normal sleep hours. You can set your normal sleep hours on your Garmin Connect™ account (Using Do Not Disturb Mode).
Auto Lock
Allows you to lock the buttons automatically to prevent accidental button presses. Use the During Activity option to lock the buttons during a timed activity. Use the Not During Activity option to lock the buttons when you are not recording a timed activity.
Format
Sets the watch to display Pace/Speed Preference for running, cycling, or other activities. This preference affects several training options, history, and alerts (Displaying Pace or Speed). You can also change the Start of Week setting and the units of measure used on the watch (Changing the Units of Measure).
Physio TrueUp
Allows your watch to sync activities, history, and data from other Garmin® devices.
Data Recording
Sets how the watch records activity data. The Smart recording option (default) allows for longer activity recordings. The Every Second recording option provides more detailed activity recordings, but may not record entire activities that last for longer periods of time. Turn the Log HRV option on to record your heart rate variability during an activity.
USB Mode
Sets the watch to use mass storage mode or Garmin mode when connected to a computer.
Reset
Allows you to reset user data and settings (Resetting All Default Settings).
Software Update
Allows you to install software updates downloaded using Garmin Express™ or the Garmin Connect app (Updating the Software Using the Garmin Connect App).
About
Displays device, software, license, and regulatory information.
GUID-3A791586-B59F-4B37-B9C5-5A41F8C6BE0B v8
December 2025
