Setting the Roll Factor
The device estimates your total distance using the carry estimate plus roll. The roll factor varies due to differences in balls, clubs, and surface conditions, as well as ball spin and launch angle. These factors cannot be detected by the device. If you are not getting the distance result you expect, you can adjust the roll factor.
  1. Select Training symbol > Driving Range > Settings > Set Roll Factor.
  2. Use the slider to increase or decrease your roll.
GUID-39C10EC9-3CDF-406D-9BC9-8F490036536A v3
August 2026
