Setting Your Device Passcode
NOTICE
If you enter your passcode incorrectly five times, the golf handheld locks. To unlock the device, you must perform a factory reset or reset it in the Garmin Golf™ app.
You can set up a device passcode to prevent unauthorized users from logging into your device.
  1. Select an option:
    • During the initial setup, select Yes when prompted to create a passcode.
    • Select Settings symbol > System > Passcode > Set Passcode.
  2. If you are not paired with the Garmin Golf app, select Enable when you are prompted to confirm passcode setup.
  3. Enter a four-digit passcode.
  4. Re-enter the passcode.
  5. Select Done.
The next time you turn on the golf handheld, you must enter the passcode before you can view any information.
GUID-39C10EC9-3CDF-406D-9BC9-8F490036536A v3
August 2026
