PlaysLike Settings
Select Settings symbol > PlaysLike.
Wind
Enables wind speed and direction to be included in the PlaysLike distance adjustments.
Weather
Enables air density to be included in the PlaysLike distance adjustments.
Home Conditions
Allows you to manually change the altitude, temperature, and humidity settings used for the air density comparison.
NOTE: It can be helpful to set weather conditions that match where you typically play. If they do not match the conditions at your normal course locations, the air density adjustments may seem inaccurate.
GUID-39C10EC9-3CDF-406D-9BC9-8F490036536A v3
August 2026
