Connecting to a Wireless Network
You can set up the Wi‑Fi® network connection using the Approach® golf handheld.
NOTE: You can also set up the Wi‑Fi network connection using the Garmin Express™ application (Setting Up Garmin Express). Some wireless features are only available through Garmin Express.
  1. On the device, select Settings symbol > System > Connectivity > Wi-Fi.
  2. If necessary, select Status to enable Wi‑Fi technology.
  3. Select My Networks > Add Network.
  4. Select a wireless network from the list.
  5. If necessary, enter the password.
The golf handheld stores the network information and connects automatically when you turn on the device.
TIP: You can also select Wi-Fi Sync to manually sync your Wi‑Fi connection.
GUID-39C10EC9-3CDF-406D-9BC9-8F490036536A v3
August 2026
