Pairing Your Phone
To use the connected features of the Approach® golf device, it must be paired directly through the Garmin Golf™ app, instead of from the Bluetooth® settings on your phone.
  1. During the initial setup on your device, select OK when you are prompted to pair with your phone.
    NOTE: If you previously skipped the pairing process, you can select Settings symbol > System > Connectivity > Pair Phone.
  2. Scan the QR code with your phone.
    NOTE: If you have not installed the Garmin Golf app on your phone, you are prompted to install it from the app store.
  3. Open the Garmin Golf app.
  4. Select Add Device.
  5. Follow the instructions in the app to complete the pairing process.
GUID-39C10EC9-3CDF-406D-9BC9-8F490036536A v3
August 2026
