Controlling Phone Calls
You can use your headset controls to answer, hang up, or hold incoming phone calls from your paired smartphone. You can move the rocker up and down, and you can press it like a button.
![Diagram of the rocker control](../Shared/GUID-4AAEDE59-2556-4B1C-AEFC-0DE9B71A281D-high.jpg)
- To increase or decrease the volume, move the rocker up or down.
- To answer incoming phone calls from your paired smartphone, move the microphone to the forward position, or press the rocker.
- To cancel an outgoing call, press the rocker while a call is in progress.
- To answer a second active call and put the first call on hold, press the rocker.
- To transfer audio to your phone, press and hold the rocker during an active call.
- To hang up a call, press the rocker.
- To reject an incoming call, press and hold the rocker.
- To switch between two active calls, press and hold the rocker.
Parent Topic: Getting Started
