Adjusting the Gain for an Auxiliary Device
You can adjust the gain for a connected auxiliary device to achieve a volume level similar to that of other media sources. You can adjust the gain in 1 dB increments. You can also adjust the gain for digital sources using an optical audio connection.
  1. Select an auxiliary source.
  2. Select an option:
    • To increase the gain, select Forward button.
    • To decrease the gain, select Back button.
    NOTE: To achieve the best audio quality when using a portable media player with headphone output, it may be necessary to adjust the volume control on the media player, instead of adjusting the gain.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
