Setting LED Lights to React to Music
WARNING
Setting LED lights to react to music may result in lights flashing at various intervals. Consult your physician if you have epilepsy or are sensitive to bright or flashing lights.
NOTICE
Before you can set connected LED lights to react to music playing on the stereo, you must use a connected chartplotter to associate a light or group of lights with an audio zone on this stereo. See the chartplotter owner's manual for complete instructions.
  1. Select Menu button > LED CONTROL.
  2. Select LIGHTS, and select the lights or group of lights you want react to music.
  3. Select AUDIO SYNC, and select an option:
    • If you want the lights to react to the intensity of the music playing, select COLOR BLEND.
    • If you want the lights to react to the bass and treble frequencies of the music playing, AUDIO SPECTRUM.
You must use a connected chartplotter if you want to change the colors used by this feature. See the chartplotter owner's manual for complete instructions.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
