Network Troubleshooting
If you cannot see or connect to Fusion Apollo™ devices on the network, perform these steps.
  • Verify that all Fusion Apollo stereos, remote controls, network switches, routers, and wireless access points are connected to the network and turned on.
  • Verify that only one device, either a stereo or a router, is configured as a DHCP server. If you are connected to a Garmin® chartplotter using a wired Garmin BlueNet™ or Garmin Marine Network connection, it acts as the DHCP server for the network and no connected stereo should be configured as a DHCP server.
  • Change the channel on your router or wireless access point to test for and correct interference.
    You may experience wireless interference if there are many nearby wireless access points.
  • Disconnect Bluetooth® devices to test for and correct interference.
    Connecting a Bluetooth device to a stereo configured as a wireless access point or client may reduce wireless performance.
  • If you configured static IP addresses, verify that every device has a unique IP address, that the first three sets of numbers in the IP addresses match, and that the subnet masks on every device are identical.
  • If you have made configuration changes that might be causing networking issues, reset all network settings to the factory default values.
  • If you connected the Fusion Apollo device to a Garmin chartplotter using a wired Garmin BlueNet or Garmin Marine Network connection, the network settings on the device should change automatically to GARMIN MARINE NETWORK.
    If the network settings do not change as expected, reset the network settings on the device (Resetting Network Settings).
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
