Specifications
Weight
475 g (16.75 oz.)
Water rating
IEC 60529 IPX21
Operating temperature range
From 0 to 50°C (from 32 to 122°F)
Storage temperature range
From -20 to 70°C (from -4 to 158°F)
Input voltage
From 10.8 to 16 Vdc
Current (max.)
15 A
Current (muted)
Less than 700 mA
Current (off)
Less than 200 mA
Fuse
15 A mini blade-type
NMEA 2000® LEN @ 9 Vdc
1 (50 mA)
Bluetooth® wireless range
Up to 10 m (30 ft.)
ANT® wireless range
Up to 3 m (10 ft.)
Wireless frequencies/protocols
Bluetooth 2.4 GHz @ 12 dBm nominal
ANT 2.4 GHz @ 11.77 dBm nominal
Compass-safe distance
15 cm (6 in.)
On-board, Class D amplifier
Output music power per channel
4 x 70 W max. 2 ohm
Total output peak power
280 W max.
Output power per channel
4 x 43 W RMS at 14.4 Vdc input, 2 ohm, 10% THD2
4 x 26 W RMS at 14.4 Vdc input, 4 ohm, 10% THD3
Line output level (max.)
5.5 V (peak to peak)
Aux input level (typical)
1 V RMS
Tuner frequencies
Tuner
Europe and Australasia
USA
Japan
FM radio frequency range
87.5 to 108 MHz
87.5 to 107.9 MHz
76 to 95 MHz
FM frequency step
50 kHz
200 kHz
50 kHz
AM radio frequency range
522 to 1620 kHz
530 to 1710 kHz
522 to 1620 kHz
AM frequency step
9 kHz
10 kHz
9 kHz
1 Vertically dripping water shall have no harmful effect when the enclosure is tilted at an angle of 15° from its normal position.
2 The stereo may limit the output power to prevent the amplifier from overheating, and to maintain the audio dynamics.
3 The stereo may limit the output power to prevent the amplifier from overheating, and to maintain the audio dynamics.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
