Connecting a Compatible Bluetooth Device
You can play media from a compatible Bluetooth® device using the Bluetooth wireless connection.
You can control the music playback with the media app on a Bluetooth device or using the Fusion® Audio remote control app (Fusion Audio Wireless Remote Control App).
  1. Select the BLUETOOTH source.
  2. Select Menu button > BLUETOOTH > CONNECTIONS > DISCOVERABLE to make the stereo visible to your compatible Bluetooth device.
    TIP: You can also press the Bluetooth symbol button on the stereo to make it discoverable.
  3. Enable Bluetooth on your compatible Bluetooth device.
  4. Bring the compatible Bluetooth device within 10 m (33 ft.) of the stereo.
  5. On your compatible Bluetooth device, search for Bluetooth devices.
  6. On your compatible Bluetooth device, select the stereo from the list of detected devices.
    NOTE: The stereo appears in the Bluetooth device list as the device name (the default name is MS-WB675 unless it was changed in the settings).
  7. On your compatible Bluetooth device, follow the on-screen instructions to pair and connect to the discovered stereo.
    When pairing, your compatible Bluetooth device may ask you to confirm a code on the stereo. If the stereo shows a code, you can compare them before pairing. If the stereo does not display a code, it should connect correctly when you confirm the message on the Bluetooth device.
  8. If your compatible Bluetooth device does not immediately connect to the stereo, repeat steps 1 through 7.
    NOTE: If another Bluetooth device is already playing music on the stereo, connecting a new device will not interrupt playback. You must select the newly-added device if you want to use it instead (Selecting a Different Bluetooth Device).
The DISCOVERABLE setting is disabled automatically after two minutes.
NOTE: On some Bluetooth devices, adjusting the volume on the device affects the volume level on the stereo.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
