Optical Audio Connection
You can connect devices with an optical audio output to the stereo using an optical audio cable. Televisions, DVD players, CD players, and other devices may supply digital optical audio output.
This stereo supports PCM audio only. You may have to change the settings on your device to output PCM audio.
NOTE: Because streaming audio over the Fusion PartyBus™ network introduces a slight delay, streaming content from a television or DVD player may not be ideal. You can disable Optical as a streaming source in the settings or disable the GROUP feature, if needed (Source Settings).
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
