Fusion Stereo Network Connection and Control
When connected using a supported networking method, you can fully control compatible Fusion® entertainment systems on compatible multi-function displays installed at the helm, flybridge, or navigation station of the vessel. This provides integrated entertainment control and a less cluttered console.
The connected multi-function display becomes the portal on which you can control all audio on the vessel, no matter where on the vessel the connected stereo is installed. The compatible Fusion stereo can be installed out of sight if space is an issue and users need to access the stereo only to replace removable media.
This device can communicate with a compatible multi-function display using existing industry-standard network connections including Ethernet and Wi‑Fi® wireless technology.
NOTE: Garmin® multi-function displays must be connected via Ethernet.
This device can communicate with a compatible multi-function display using existing industry-standard NMEA 2000® networks.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
