Configuring the DSP Settings
You must download and install the Fusion® Audio remote control app on your compatible Apple® or Android™ device before you can configure the DSP settings (Fusion Audio Wireless Remote Control App).
You can configure the DSP settings to optimize the sound on each zone with the installed speakers, amplifiers, and environment.
  1. From the settings menu on your Apple or Android device, connect to the stereo using Bluetooth® technology or connect to the same wireless network as the stereo.
    NOTE: If you have a compatible Apple device, you can use a Lightning™ to USB sync cable (sold separately) connected to the USB port on the stereo and to your Apple device to configure the DSP settings using the Fusion Audio app.
  2. Open the Fusion Audio remote control app on your compatible Apple or Android device.
  3. If necessary, select the stereo you want to configure.
  4. Select Settings symbol.
  5. If necessary, select the MUSIC tab.
  6. Select a zone.
  7. Select DSP SETTINGS.
  8. Configure the DSP settings as needed, depending on the models of Fusion speakers and amplifiers connected to the zone.
  9. Select SEND DSP SETTINGS.
    NOTE: DSP settings or updates for the zone are not applied on the stereo until you select the button to send the settings.
  10. Repeat these steps for each zone.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
January 2025
