Turning on LED Light Effects
ADVARSEL
Valg af visse LED-lyseffekter kan medføre, at lysene blinker med forskellige intervaller. Konsulter din læge, hvis du har epilepsi eller er følsom over for skarpt lys eller blinklys.
The Garmin Spectra™ lighting controller has a selection of preprogrammed lighting effects that you can turn on using the stereo.
  1. Select Menuknap > LED-betjening.
  2. Select Lygter and select the lights or group of lights you want to use a lighting effect.
  3. Select Effekter and select one of the preprogrammed lighting effects to start it on the connected lights.
GUID-38C8EEA6-CA0D-46DE-B7DA-A3AC6EDE85DE v5
Januar 2025
