Configuring the Wi‑Fi Network
NOTE: If your radio is connected to a compatible Garmin® chartplotter over a Garmin BlueNet™ network, you cannot configure a Wi‑Fi® network on the radio. You must use the chartplotter Wi‑Fi network instead. See the chartplotter Owner's Manual for instructions on setting up the chartplotter Wi‑Fi network.
  1. Select Menu icon > Settings > Wi-Fi.
  2. If necessary, select Enable Wi-Fi.
  3. Note the Wi‑Fi network SSID shown in the SSID field.
  4. Select Password.
  5. Using the virtual keyboard on the radio screen, enter a password for the radio's Wi‑Fi network.
    NOTICE
    The Wi‑Fi network provides access to configuration and data stored on your radio. You should keep the password secret to prevent unauthorized access.
  6. Select Done.
GUID-376DCF06-863E-4772-9B73-834F8852F379 v1
June 2026
