Saving a VHF Channel as a Preset
You can save the VHF channels you use most often to four configurable slots on the VHF screen.
  1. Tune the radio to a VHF channel you want to save as a preset.
  2. Hold a slot 1 to save the current channel to that slot.
    VHF Radio screen with callout
  3. Select Set.
    If there was already a channel saved to the slot, the new channel overwrites the old one.
You can touch the slot to tune to the preset channel.
A green dot appears on the top right corner of the preset button if there has been activity on that channel in the last three minutes.
NOTE: You can use the Presets watch mode to monitor all your presets at the same time (Watch Modes).
GUID-376DCF06-863E-4772-9B73-834F8852F379 v1
June 2026
