Setting the Wakeup Phrase
The wakeup phrase is a word or phrase you can say to activate voice command. The default wakeup phrase is Voice Command.
TIP: You can reduce the chance of accidental voice command activation by using a strong wakeup phrase.
  1. Select Apps > Navigation > Voice Command > Settings > Wake Up Phrase.
  2. Enter a new wakeup phrase.
    The device indicates the strength of the wakeup phrase as you enter the phrase.
  3. Select Done.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
