Viewing a Vehicle Camera
Before you can view a vehicle camera, a compatible camera must be connected to the stereo.
Before you can view cameras automatically, you must enable camera auto-display options (Enabling Camera Auto-Display).
  1. Select an option to view a vehicle camera:
    • To automatically show the backup camera, place the vehicle into reverse.
    • To automatically show a side-mirror camera, activate the vehicle turn signal.
      NOTE: This option is typically available only as a manufacturer option on select vehicles, and may not be available on your vehicle.
    • To manually show the backup camera, select Apps > Camera.
    The vehicle camera view appears on the screen.
  2. If available, select Microphone to mute or unmute audio from the camera microphone.
    TIP: If the vehicle camera microphone is connected and this option is not available, verify the microphone is enabled (Enabling the Vehicle Camera Microphone).
  3. Select an option to resume normal operation:
    • Take the vehicle out of reverse.
    • Deactivate the vehicle turn signal.
    • Select Back.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
