Navigating to a Saved Trip
Before you can start navigating a saved trip, the active vehicle profile on the device must match the selected vehicle profile for the trip (Changing Routing Options for a Trip). If it does not match, the device prompts you to change the vehicle profile before you can start the trip (Switching the Vehicle Profile).
  1. Select Apps > Trip Planner > Saved Trips.
  2. Select a saved trip.
  3. Select Go!.
  4. Select the first location to navigate to, and select Start.
    The device calculates a route from your current location to the selected location, and then it guides you to the remaining trip destinations in order.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
