Using the Map
You can use the map to navigate a route (Your Route on the Map) or to view a map of your surroundings when no route is active.
  1. Select View Map.
  2. Touch anywhere on the map.
  3. Select an option:
    • Drag the map to pan left, right, up, or down.
    • To zoom in or out, select Zoom in or Zoom out.
    • To switch between North Up and 3-D views, select Map view.
    • To filter the displayed points of interest by category, select Search.
    • To start a route, select a location on the map, and select Go! (Starting a Route by Using the Map).
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
