Specifications
Display Specifications |
Operating temperature range |
From -20 to 55°C (from -4 to 131°F) |
Charging temperature range |
From 0 to 45°C (from 32 to 113°F) |
Wireless frequency/protocol |
2.4 GHz @ 15 dBm nominal |
Power input |
Vehicle power using the included vehicle power cable. AC power using an optional accessory (for home and office use only). |
Battery type |
Rechargeable lithium-ion |
Dock Specifications |
From -10 to 55°C (from 14 to 131°F) |
Storage temperature range |
From -20 to 70°C (from -4 to 158°F) |
Input voltage |
From 10.8 to 16 Vdc |
Current (max.) |
15 A |
Current (standby mode) |
Less than 5 mA |
Fuse |
15 A mini blade type |
2.4 GHz @ 7.9 dBm nominal |
On-board, Class D Amplifier |
Output music power per channel |
4 x 70 W max. 2 ohm |
Total output peak power |
280 W max. |
Output power per channel |
4 x 43 W RMS at 14.4 Vdc input, 2 ohm, 10% THD1 4 x 26 W RMS at 14.4 Vdc input, 4 ohm, 10% THD2 |
Line output level (max.) |
5.5 V (peak to peak) |
Aux. input level (typical) |
1 V RMS |
Tuner |
Europe and Australasia |
USA |
Japan |
FM radio frequency range |
87.5 to 108 MHz |
87.5 to 107.9 MHz |
76 to 95 MHz |
FM frequency step |
50 kHz |
200 kHz |
50 kHz |
AM radio frequency range |
522 to 1620 kHz |
530 to 1710 kHz |
522 to 1620 kHz |
AM frequency step |
9 kHz |
10 kHz |
9 kHz |
