Connecting a Compatible Bluetooth Device
You can play media from a compatible Bluetooth® device using the Bluetooth wireless connection.
You can control the music playback with the media app on a Bluetooth device or using the FUSION-Link™ remote control app (FUSION-Link Wireless Remote Control App).
  1. Select the BT source.
  2. Select Menu > CONNECTIONS > DISCOVERABLE to make the stereo visible to your compatible Bluetooth device.
  3. Enable Bluetooth on your compatible Bluetooth device.
  4. Bring the compatible Bluetooth device within 10 m (33 ft.) of the stereo.
  5. On your compatible Bluetooth device, search for Bluetooth devices.
  6. On your compatible Bluetooth device, select the stereo from the list of detected devices.
  7. On your compatible Bluetooth device, follow the on-screen instructions to pair and connect to the discovered stereo.
    When pairing, your compatible Bluetooth device may ask you to confirm a code on the stereo. The stereo does not display a code, but it does connect correctly when you confirm the message on the Bluetooth device.
  8. If your compatible Bluetooth device does not immediately connect to the stereo, repeat steps 1 through 7.
The DISCOVERABLE setting is disabled automatically after two minutes.
NOTE: On some Bluetooth devices, adjusting the volume on the device affects the volume level on the stereo.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
