Using In-Call Options
In-call options appear when you answer a call. Some options may not be compatible with your phone.
TIP: If you close the in-call options page, you can open it again by selecting Phone from the main menu.
  • To set up a conference call, select Add call.
  • To transfer audio to your phone, select Transfer handset.
    TIP: You can use this feature if you want to disconnect the Bluetooth® connection and remain on the call, or if you need privacy.
  • To use the dial pad, select Dial pad.
    TIP: You can use this feature to use automated systems, such as voice mail.
  • To mute the microphone, select Mute microphone.
  • To hang up, select Hang up.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
