Adding a Vehicle Profile
You should add a vehicle profile for each camper to be used with your device.
  1. Select Apps > Navigation > Vehicle Profile > Add profile.
  2. Select your vehicle type:
    • To add a motorhome with a permanently attached camper, select Motorhome.
    • To add a motorhome pulling a trailer, select Motorhome with Trailer.
    • To add a camper pulled behind a passenger vehicle, select Vehicle with Trailer.
  3. If necessary, select your trailer type:
    • To add a camper pulled using a standard hitch, select Travel Trailer.
    • To add a camper pulled using a fifth-wheel hitch, select Fifth Wheel.
      NOTE: This trailer type is not available in all areas.
    • To add a boat trailer pulled using a standard hitch, select Boat Trailer.
    • To add a trailer pulled using a standard hitch, select Trailer.
  4. Follow the on-screen instructions to enter the vehicle characteristics.
After you add a vehicle profile, you can edit the profile to enter additional detailed information (Editing a Vehicle Profile).
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
