Scanning for DAB Stations
NOTE: Because DAB signals are broadcast in select countries only, you must set the tuner region to a location where DAB signals are broadcast.
  1. Select the DAB source.
  2. Select Play or pause to scan for available DAB stations.
    When scanning is complete, the first available station in the first ensemble found begins playing.
    NOTE: After the first scan is complete, you can select Play or pause again to re-scan for DAB stations. When the re-scan is complete, the system starts playing the first station in the ensemble you were listening to when you started the re-scan.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
