Network Troubleshooting
If you cannot see or connect to FUSION PartyBus™ devices on the network, check the following:
  • Verify that only one device, either a stereo or a router, is configured as a DHCP server.
  • Verify that all FUSION PartyBus devices, network switches, routers and wireless access points are connected to the network and turned on.
  • Verify that wireless FUSION PartyBus devices are connected to a wireless router or wireless access point on the network.
  • If you configured static IP addresses, verify that every device has a unique IP address, that the first three sets of numbers in the IP addresses match and that the subnet masks on every device are identical.
  • If you have made configuration changes that might be causing networking issues, reset all network settings to factory defaults.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
