Opening the Digital Switching Controls
For most installations, digital switching modules connect to the Vieo™ RV 750 dock using a Controller Area Network (CAN) bus. The Vieo RV 750 system also supports EmpirBus™ Connect 50 Wi‑Fi® digital switching systems that connect to the Vieo RV 750 dock without a CAN connection.
NOTE: Your installation may include a widget to open the system controls from the home screen.
- If your device is connected to modules using a Controller Area Network (CAN) bus, select .
- If you are using an EmpirBus Connect 50 Wi‑Fi digital switching system, select .
Parent Topic: Onboard Systems Control and Monitoring
