Setting the FUSION PartyBus Device as the DHCP Server
If you connected two FUSION PartyBus™ devices together directly, or connected more than two together using a network switch or wireless access point and did not install a router, you must configure only one FUSION PartyBus stereo to be the DHCP server.
  1. Select Apps > ToolsMusic > Settings > Network > Advanced > Ethernet IP > Static IP > Save.
  2. Select Apps > ToolsMusic > Settings > Network > Advanced > DHCP Server > DHCP Enabled > Save.
    You can configure the IP address range of the DHCP server (DHCP Settings).
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
