Setting the FUSION PartyBus Device as a Wireless Access Point
Before you can connect additional FUSION PartyBus™ devices or smartphones to a FUSION PartyBus device wirelessly, you must configure at least one device as a wireless access point. This is not necessary if you installed a wireless router or other wireless access point on the network.
  1. Select Apps > Tools > Music > Settings > Network > WI-FI ACCESS POINT.
  2. Select SSID and change the default SSID, or name, for the wireless access point (optional).
  3. Select AP Security: %1 and change the security type for the access point (optional).
    NOTE: It is strongly recommended that you use the default WPA2 Personal AP Security: %1 setting. It is the most widely used and secure wireless security protocol.
  4. Select Password and change the default password for the access point (optional).
  5. If necessary, select Country: %1 and select your region.
  6. Select Channel: %1 and select a channel range for the access point (optional).
  7. Select Save.
    You can adjust the wireless access point configuration at any time (Wireless Access Point Settings).
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
