Specifications
| Display Specifications | |
| Operating temperature range | From -20 to 55°C (from -4 to 131°F) |
| Charging temperature range | From 0 to 45°C (from 32 to 113°F) |
| Wireless frequency/protocol | 2.4 GHz @ 15 dBm nominal |
| Power input | Vehicle power using the included vehicle power cable. AC power using an optional accessory (for home and office use only). |
| Battery type | Rechargeable lithium-ion |
| Dock Specifications | |
| Operating temperature range | From -10 to 55°C (from 14 to 131°F) |
| Storage temperature range | From -20 to 70°C (from -4 to 158°F) |
| Input voltage | From 10.8 to 16 Vdc |
| Current (max.) | 15 A |
| Current (standby mode) | Less than 5 mA |
| Fuse | 15-A mini blade type |
| Wireless frequency/protocol | 2.4 GHz @ 7.9 dBm nominal |
| On-board, Class-D Amplifier | |
| Output music power per channel | 4 x 70 W max. 2 ohm |
| Total output peak power | 280 W max. |
| Output power per channel | 4 x 43 W RMS at 14.4 Vdc input, 2 ohm, 10% THD1 4 x 26 W RMS at 14.4 Vdc input, 4 ohm, 10% THD2 |
| Line output level (max.) | 5.5 V (peak to peak) |
| Aux. input level (typical) | 1 V RMS |
| Tuner | Europe and Australasia | USA | Japan |
| FM radio frequency range | 87.5 to 108 MHz | 87.5 to 107.9 MHz | 76 to 95 MHz |
| FM frequency step | 50 kHz | 200 kHz | 50 kHz |
| AM radio frequency range | 522 to 1620 kHz | 530 to 1710 kHz | 522 to 1620 kHz |
| AM frequency step | 9 kHz | 10 kHz | 9 kHz |
