Display settings
Select Apps > Tools > Settings > Display.
Brightness Level
Sets the display brightness level on your device.
Adaptive Brightness
Automatically adjusts the backlight brightness based on the ambient light when the device is out of the mount.
Theme
Allows you to select day or night colour mode. If you select the Automatic option, the device automatically switches to day or night colours based on the time of day.
Wallpaper
Sets the wallpaper background on your device.
Sleep
Allows you to set the amount of idle time before your device enters sleep mode while using battery power.
Daydream
Enables or disables the daydream screen saver.
Font size
Increases or decreases the font size on your device.
When device is rotated
Enables the screen to rotate automatically between portrait and landscape display modes based on the device orientation or remain in the current orientation.
NOTE: The navigation map supports landscape mode only.
Copyright © Garmin. All rights reserved.GUID-31BF71FA-C94A-4E45-AB5F-B85B7AEF6A73 v4
